YEAR93
Is it possible to display the search results count? For example -> 970 search results. If so, How?
For reference, could you share the link to your site? I’ll check how your Search page is setup and see what code is needed.
YEAR93
View below
Try adding this snippet:
function custom_search_result_title( $items) { if ( is_search() ) { global $wp_query; $found_posts = $wp_query->found_posts; $items = $items . '<h3 class="found-posts-count">' . $found_posts . ' Results</h3>'; } return $items; } add_filter( 'generate_search_title_output', 'custom_search_result_title', 9999, 2 );
YEAR93
Is it possible to make a shortcode of this snippet or can you explain how I add this in front of the search results page title? The title is now “Zoekresultaten voor: … ” but I want this to be “23 zoekresultaten voor: … “.
Use function below to create shortcode
[custom_search_result_title]
:function custom_search_result_title_shortcode( $atts ) { ob_start(); if ( is_search() ) { global $wp_query; $found_posts = $wp_query->found_posts; echo '<h3 class="found-posts-count">' . $found_posts . ' Results</h3>'; } $output = ob_get_clean(); return $output; } add_shortcode( 'custom_search_result_title', 'custom_search_result_title_shortcode' );
YEAR93
Thank you, and where can I add this? Because it looks like the title on my search results pages isn’t from my custom content block but maybe from an theme template file?
What do you mean?
YEAR93
View screenshot 1 displays the current appearance of the search results page title, while screenshot 2 illustrates what I want to achieve.
You don’t want it to show the 3?
YEAR93
I want the count of the search results to be displayed in the page title of the search results page.
I see. It won’t be a Shortcode though. Try this code instead:
function custom_search_result_title( $items) { if ( is_search() ) { global $wp_query; $found_posts = $wp_query->found_posts; $myreplace = '</h1>'; $myinsert = '<span class="found-posts-count"> ' . $found_posts . ' Results</span></h1>'; $items = str_replace( $myreplace, $myinsert , $items ); } return $items; } add_filter( 'generate_search_title_output', 'custom_search_result_title', 9999, 2 );
YEAR93
Works, but that snippet isn’t adding the count inside the page title.
Could you reactivate the code? I’ll check what’s going on.
YEAR93
Okay, I did now.
I see. I updated the code I just shared above. Can you try that instead?
