Secondary Navigation Button Color
  • Hi —
    I’d like to set a color on the first item in this secondary navigation, placed before the header on my site. I have added a custom class – ac-button – as outlined here https://docs.generatepress.com/article/adding-buttons-navigation/, but the color isn’t showing up for me. Can you help me to troubleshoot this?
    Can you disable your caching plugin first so I can see the CSS you are adding?
  • There’s no caching plugin, but it is on WP Engine. I’m not sure what I need to do…?
  • Can you provide the CSS you’ve added here?
  • Sure — I used —
    @media (min-width:769px) {
        .secondary-navigation .main-nav ul li.ac-navbutton a {
            background-color: #f3c559;
            color: #ffffff;
            line-height: 35px; /*this number will likely need to be adjusted*/
    ac-navbutton is the name I added in the Custom Class field on the menu item.
  • ac-navbutton is the name I added in the Custom Class field on the menu item.
    The class name you added is actually ac-button:
    https://www.screencast.com/t/QqWyveCXbmeS
    So your CSS should be:
        .secondary-navigation .main-nav ul li.ac-button a {
            color: #ffffff;
    If this still doesn’t help then please check with your hosting support to see how to disable caching.
