Anonymous
I’m trying to add a secondary navigation menu to the top of a website (before the header) using the instructions in this post https://generatepress.com/forums/topic/i-want-to-have-a-second-menu-on-certain-pages-what-is-the-best-way/, and I’m not able to make it work. I have added it as a Hook Element using thegenerate_before_header
with a priority of 15. Under Display Rules, I have chosen Entire Site.Again, I’m using this code as suggested in the post:
<div class="second-nav"> <?php if ( function_exists( 'generate_secondary_navigation_position' ) ) { generate_secondary_navigation_position(); } ?> </div>
As you can see, the menu appears twice. Can you tell me what I’m doing wrong? Also, is there a way to align that secondary menu to the left before the header?
Are you trying to add the secondary nav to the entire site or specific pages?
Anonymous
Hi, Ying!
Ultimately, I’d like to add it throughout the website so I chose Entire Site. I had asked a question a few weeks ago (https://generate.support/topic/is-there-a-way-to-achieve-this-look-with-gp-gb/) about a top bar effect that was similar to a tabbed look, but I think it would be easier to achieve with this menu.
Thanks for your help! -
If this is the case, you do not need to add the code, just set the secondary navigation location to above header at customizer > layout > secondary navigation, which it seems you have done.
So remove the hook element should fix the issue.
Anonymous
This is perfect so far. Thanks so much. Now, is there a way for me to get this menu left aligned?
Thanks! -
Can I see your site?
Can you please let me know where I can find the secondary navigation option? I don’t see it on my theme. Im using your child theme and there’s no option visible for a secondary menu.
Thank you. -
Please make sure the Secondary Nav add-on is activated: https://docs.generatepress.com/article/installing-gp-premium/#activate-your-modules
If that doesn’t help then please open a new support topic for your question.
- The topic ‘Secondary Navigation Menu Before Header’ is closed to new replies.
