Seo button
  • Hello, in generatepress I can add a <h2> tag to the text of a button, for example, it is for SEO reasons, thanks in advance
    h2 tags are not supposed to be added to a button.
    You can use a container, and add h2 to the container, then add a container link to the container, it can visually look like a button, but it’s a div in HTML.
    Hope that works for you!
  • Ok, I’m going to listen to you and rethink the buttons as another visual element, for the SEO issue, once again thank you.
  • You are welcome   🙂
