designitlife
Hello! I need help to make service plan. I can’t see any option to make service plan. Please help. Thank you
Regards
Designitlife -
i am not sure what you mean…. can you explain ?
designitlife
I am a graphic designer. I want to make some service plans. Giving you link; This type of I want to make.
Ok… still not clear.
So is it a copy of that entire page ? Or just part of it ? -
designitlife
I just want to make service section like photo background remove type service
Could you help me out and provide a screenshot of the part you want to create ?
designitlife
I sent screenshot at email
For refernence here is that image.
https://app.screencast.com/34ij1R5D0FuNc
To share images in the forum you need to provide a link to the images location that you can share via cloud drive or a sharing service.
So we have a title and image to the left and to the right a set of tabs.
On Fivver those tabs have buttons that “do something” – what will this do on your website ? -
designitlife
Hello! I just want to know how to make service plans. Kindly visit fiverr.com website there you can see the plans. However you should know how to make it.
Regards
Designitlife -
I need to know the answer to this:
designitlife
My meant to say I want to add service plan on my service page. Do you not know how to make service plan on page?
designitlife
I don’t know about it -
You can create a new page.
And then use the GenerateBlocks plugin to build your Service Plan. -
designitlife
Hello! I will try it. If I will stuck will ask to you. Thank you for the help.
Regards
Designitlife -
designitlife
I have another question that how many plugins should we use in wordpress? I mean maximum
There isn’t a limit for the number of plugins you can use.
The most important part is to make sure that the plugins you are using are all well-coded and lightweight.
This is something you can test by running a performance/speed test before and after activating the plugins.
Hope this helps 🙂
