webbplatsen
Can I set container width using global styles?
I have following blocks and each container is 50% which is local setting.
I want to set width using global style but it will not work.
Maybe I don’t need to tell you more details if this isn’t possible 😉[Grid]
[Container]
[Container] -
Are you trying to apply the global styles to the Grid block?
webbplatsen
No, the containers.
I thought global styles on Grid block isn’t possible, -
It is possible, but there’s currently a bug that prevents the global styles option from showing up in the Grid Block. This will be fixed in the next release.
webbplatsen
Oh well …good to know.
No problem! Happy to help.
