Setting for menu item height for sticky navigation mobile
  • Hi Fernando,
    Please see attached.
    Charles
  • fernandoazarcon2
    You have an extra } at the very bottom of Additional CSS. It’s causing a syntax error. Can you remove that first? Let’s see how it goes afterward.
  • Hi Fernando,
    Thanks for pointing that out. I’ve removed that.
    Still no luck with the menu on mobile.
    Charles
  • fernandoazarcon2
    I see. You’re using a mobile header. Try this:
     nav#mobile-header.is_stuck {
        min-height: 100px;
    I’ve added the above CSS and switched the value to 55px but still no luck.
    Charles
  • Hi Charles,
    Do you want the sticky navigation looks exactly the same as the navigation?
    If so, I would recommend disabling the GP sticky navigation option and using this CSS to make the navigation sticky:
    nav#site-navigation,nav#mobile-header {
        position: sticky;
        top: 0;
    Let me know if this helps!
  • Hi Ying,
    Thank you, that’s done it.
    Charles
  • You are welcome   🙂
Viewing 8 posts - 11 through 18 (of 18 total)
