markushasselryd
Hi, I’ve got a ACF image field on an options page that is set to return an image-array. I use the following dynamic tag to display it in an element block that is hooked in as a mega menu;
{{option key:om-oss_karriar_bild.url|size:portrait}}Not sure if I use the wrong syntax but the tag only returns the original full image. I’ve tried with the standard image sizes as well, like medium, medium_large. It works when I use the size variabel in query loops for featured images on other places on the site but not here. Are there limitations when using the options page or the ACF image field?
Kind regards, Markus
That’s right, the size option is only available for the featured image.
markushasselryd
Ok, any plans in the roadmap to integrate this option for post meta fields?
If the custom field is returning an array, you need to use this format:
{{option key:om-oss_karriar_bild.sizes.medium}} -
markushasselryd
Hi Alvind, thanks, that worked great!
You’re welcome, glad to hear that!
