Setup GenerateBlocks Pro — Plus error!
  • Hi All!
    I just installed it GenerateBlocks Pro — Plus, but when I go to the domain/wp-admin/plugins.php, I get an error!
    There has been a fatal error on your website. Please check your email used for website administration for instructions.
    Please help me!
  • Hi Thuan,
    GB Pro shouldn’t cause that.
    Where did you download GB Pro? Did you get it from here?: https://generateblocks.com/account/
    Did you install another plugin as well?
    Can you try deactivating GB Pro?: https://www.wpbeginner.com/plugins/how-to-deactivate-all-plugins-when-not-able-to-access-wp-admin/
  • Hi fernandoazarcon2!
    GenerateBlocks
    GP Premium
    Lightweight Accordion
    LiteSpeed Cache
    Yoast SEO
    Yoast SEO Premium
    Here are all the plugins I’m using!
    I don’t know GenerateBlocks Pro — Plus is there any plugin that I have installed!
  • Can you try to deactivate each plugin one by one and check if you’re able to go to domain/wp-admin/plugins.php?
    Let us know how it goes.
  • I don’t understand why either! I’m trying to recover (file and database) but still not working!
    It only fails at: /wp-admin/plugins.php
    Still working normally at: /wp-admin/plugin-editor.php and /wp-admin/plugin-install.php
  • Are you able to access and disable plugins as instructed here?: https://www.wpbeginner.com/plugins/how-to-deactivate-all-plugins-when-not-able-to-access-wp-admin/
    If so, are you able to determine which plugin specifically is causing the issue?
  • @fernandoazarcon2: You really enthusiastic! Thank you very much!
    I’ve tried changing the theme to Twenty Twenty-Three and disalbe the entire plugin, but still the url is wrong: /wp-admin/plugins.php
    I installed generateblock this morning on the 2 websites (House.com.vn – newcitythuthiem.com) and both websites have errors. Other websites (on the same host) are still normal!
    I am trying to contact the host (hawhost) to restore my hosting package. Hope it works again!
    U can test at:
    https://newcitythuthiem.com/wp-admin/plugins.php
    user: test
    pass: testerror2023
    can you enable wp_debug and then share the error log ?
    https://wordpress.org/documentation/article/debugging-in-wordpress/
  • Hi David!
    Please view error after turning on wp_debug !
    Fatal error: Uncaught TypeError: Unsupported operand types: string + int in /home/canhoorg/public_html/newcitythuthiem.com/wp-admin/includes/class-wp-plugins-list-table.php:189 Stack trace: #0 /home/canhoorg/public_html/newcitythuthiem.com/wp-admin/plugins.php(534): WP_Plugins_List_Table->prepare_items() #1 {main} thrown in /home/canhoorg/public_html/newcitythuthiem.com/wp-admin/includes/class-wp-plugins-list-table.php on line 189
    There has been a critical error on this website. Please check your site admin email inbox for instructions.
    Learn more about troubleshooting WordPress.
    Deprecated: Return type of Requests_Cookie_Jar::offsetExists($key) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/Requests/Cookie/Jar.php on line 63
    Deprecated: Return type of Requests_Cookie_Jar::offsetGet($key) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/Requests/Cookie/Jar.php on line 73
    Deprecated: Return type of Requests_Cookie_Jar::offsetSet($key, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/Requests/Cookie/Jar.php on line 89
    Deprecated: Return type of Requests_Cookie_Jar::offsetUnset($key) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/Requests/Cookie/Jar.php on line 102
    Deprecated: Return type of Requests_Cookie_Jar::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/Requests/Cookie/Jar.php on line 111
    Deprecated: http_build_query(): Passing null to parameter #2 ($numeric_prefix) of type string is deprecated in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/Requests/Transport/cURL.php on line 345
    Deprecated: Return type of Requests_Utility_CaseInsensitiveDictionary::offsetExists($key) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/Requests/Utility/CaseInsensitiveDictionary.php on line 40
    Deprecated: Return type of Requests_Utility_CaseInsensitiveDictionary::offsetGet($key) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/Requests/Utility/CaseInsensitiveDictionary.php on line 51
    Deprecated: Return type of Requests_Utility_CaseInsensitiveDictionary::offsetSet($key, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/Requests/Utility/CaseInsensitiveDictionary.php on line 68
    Deprecated: Return type of Requests_Utility_CaseInsensitiveDictionary::offsetUnset($key) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/Requests/Utility/CaseInsensitiveDictionary.php on line 82
    Deprecated: Return type of Requests_Utility_CaseInsensitiveDictionary::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/Requests/Utility/CaseInsensitiveDictionary.php on line 91
  • Hi David!
    Can you help me?
    I have asked hawhost support to restore the file and database but still can’t fix it!
    I await your response!
    Thank you so much!
    [28-Mar-2023 05:55:26 UTC] PHP Deprecated: preg_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/formatting.php on line 5397
    [28-Mar-2023 05:55:26 UTC] PHP Deprecated: trim(): Passing null to parameter #1 ($string) of type string is deprecated in /home/canhoorg/public_html/newcitythuthiem.com/wp-includes/pluggable.php on line 598
    [28-Mar-2023 05:55:38 UTC] PHP Fatal error: Uncaught TypeError: Unsupported operand types: string + int in /home/canhoorg/public_html/newcitythuthiem.com/wp-admin/includes/class-wp-plugins-list-table.php:189
    Stack trace:
    #1 {main}
    [28-Mar-2023 05:55:41 UTC] PHP Fatal error: Uncaught TypeError: Unsupported operand types: string + int in /home/canhoorg/public_html/newcitythuthiem.com/wp-admin/includes/class-wp-plugins-list-table.php:189
    Stack trace:
    #1 {main}
    [28-Mar-2023 05:55:42 UTC] PHP Fatal error: Uncaught TypeError: Unsupported operand types: string + int in /home/canhoorg/public_html/newcitythuthiem.com/wp-admin/includes/class-wp-plugins-list-table.php:189
    Stack trace:
    #1 {main}
