Use wpcode snippets expressed as shortcodes within GB Pro Tabs, but the front end is unresponsive: tabs wont move on past the first, content displayed but not functional. cleared all cache.
You need to check your LiteSpeed configuration, as that appears to be the cause of the issue. When the plugin is turned off, the tab functionality works as expected.
