Show/hide block accordion to post date
  • I have a query loop and inside I have a headline block with the class of new-article. I have written some code to hide that block when the post associated with that block is more than 24 hours:
    add_filter('render_block', function ($block_content, $block) {
        // Check if the block has the class "new-article"
        if (!is_admin() && !empty($block['attrs']['className']) && strpos($block['attrs']['className'], 'new-article') !== false) {
            // Check if 'data' and 'postId' keys exist
                // Get the post ID associated with the block
                $post_id = $block['attrs']['data']['postId'];
                // Check if the post is older than 24 hours
                $post_date = get_the_time('U', $post_id);
                $current_time = current_time('timestamp');
                $time_difference = $current_time - $post_date;
                // If the post is older than 24 hours, hide the block
                if ($time_difference >= 86400) { // 86400 seconds = 24 hours
                    return '';
        return $block_content;
    }, 10, 2);
    It works, but I get a PHP warning:
    Warning: Undefined array key "data" in /home/[sitename]/[siteURL]/wp-content/themes/theme-name/functions.php on line 149
    Line 149 is: $post_id = $block['attrs']['data']['postId'];
    I tried adding a check:
            if (isset($block['attrs']['data']) && isset($block['attrs']['data']['postId'])) {
                    return '';
    }, 10, 2);
    But now the headline block always shows. What am I doing wrong?
    Why not use $post_id = get_theID(); instead of $post_id = $block['attrs']['data']['postId'];?
  • Doing that is not working as intended because the headline block always shows.
    Sorry, thread title should have been: Show/hide block according to post date!
  • It should not, i just tested on my site and it works.
  • I get Uncaught Error: Call to undefined function get_theID() in wp-content/themes/theme_name/functions.php:152
    Sorry, there was a typo in Ying’s code. It should be get_the_ID().
    Can you try that instead?
  • Here is my code so far:
                $post_id = get_the_ID();
                    return '';
    }, 10, 2);
    The block is always visible, though.
    i think this is what Ying meant:
        if (
            !is_admin() &&
                return '';
    }, 10, 2);
  • Yes, I see, it works, thanks!
  • You’re welcome
