melonbird
I’m using the Post Meta block element to display the date and author under post titles. I have it set to show the last modified date, with a text block that says “Updated:” before it. But when a post is first published, it just shows “Updated:” and then the author’s name. No date.
Is there a way to have it show “Published: [date]” on posts that have never been updated, and updated on those that have been?
if you set the Date to show the Published date, there is an option to display the Updated date if there is one.
melonbird
Thats the core Date Block.
Don’t use that.
Replace it with a GenerateBlocks Headline Block, and in the block settings ( sidebar ) activate the Dynamic Data and set the Content Source to Date.There you will see the options. -
melonbird
Thank you! That got the date working. This is probably a long shot, but is there any way to have the word “Published” or “Updated” before the date, depending which it is? If not, I may just remove that word altogether.
A simple method would be to add the label using CSS:
.entry-date.published:before { content: "Published: " } .entry-date.updated-date:before { content: "Updated: " }
melonbird
Thank you! That’s brilliant.
You’re welcome
