Show star rating on archiv pages
  • Hi 🙂
    I want to show the star rating on my recipe archiv pages. Therefore I have to implement that peace of code:
    echo '<article class="post-summary">';
    	echo '<a class="entry-image-link" href="' . get_permalink() . '" tabindex="-1" aria-hidden="true">' . get_the_post_thumbnail( get_the_ID(), 'small_thumbnail' ) . '</a>';
    	echo '<header class="post-summary__content">';
    		be_star_rating();
    		echo '<h4 class="entry-title"><a href="' . get_permalink() . '">' . get_the_title() . '</a></h4>';
    	echo '</header>';
    echo '</article>';
    But where I should place that code in the theme?
    Greetings Kathrin
    can you share a link to an archive page on your site ?
  • Sure, I have added the link in the private section.
    Thank you very much!
    Greetings Kathrin
  • I don’t see anything in the private info field.
    Please confirm.
  • Next try, I hope it works now 🙂
    Greetings Kathrin
  • If the be_star_rating(); function returns the star rating for the current post object then you can:
    1. create a new Hook Element ( not a block element ).
    2. set the Hook to: generate_after_entry_title
    3. set the Display rules location to the archive pages you require it on.
    4. in the Hook editor add:
    <?php be_star_rating(); ?>
    5. check the Execute PHP option.
  • Ok, I will try it. This code should be inserted in the code snippets plugin. Do I need it also? It is the first part before the echo… :
     * Star Rating
     * @see https://www.billerickson.net/include-recipe-rating-on-archive-pages
    function be_star_rating() {
    	// Return early if WP Recipe Maker isn't active
    	if( ! class_exists( 'WPRM_Recipe_Manager' ) )
    		return;
    	global $post;
    	$recipes = WPRM_Recipe_Manager::get_recipe_ids_from_content( $post->post_content );
    	if ( isset( $recipes[0] ) ) {
    		$recipe_id = $recipes[0];
    		echo do_shortcode( '[wprm-recipe-rating id="' . $recipe_id . '"]' );
    Greetings Kathrin
  • Yes, the code is needed for <?php be_star_rating(); ?> to work.
  • Thank you very much, it works great. Maybe it is possible to change the position. The stars should appear on the archiv pages after the featured image, but I can’t find a hook related to the featured image.
    Greetings Kathrin
  • To position it after the featured image, change the Hook to:
    generate_after_entry_header and set the Priority to 20
