Simple toc CSS
  • Hello, I want to replace Kadence’s Table of Contents with Simple TOC.
    I have already managed to customize the appearance using GenerateBlocks Selectors.
    All that’s left is to customize the arrow, as shown in the image. However, this will probably require custom CSS. It is most likely a system arrow that automatically appears with the <summary> tag.
    IMAGE: https://imgur.com/a/ubeNiUX
    I need to:
    1. Remove the arrow
    2. Use CSS to create a new one so that it appears on the right side, as in Kadence TOC
    I understand that this is probably beyond the scope of this support. But maybe you can advise me on the right CSS.:)
    Thank you
    Try this CSS:
    /* Chrome, Edge, Safari */
    details > summary::-webkit-details-marker {
      display: none;
    /* Firefox */
    details > summary {
      list-style: none;
      position: relative;
    /* Modern browsers (spec-compliant) */
    details > summary::marker {
      content: "";
    details > summary:before, details > summary:after {
      content: "";
      background-color: currentColor;
      height: 2px;
      position: absolute;
      top: 11px;
      transition: all ease-in-out 0.1333333333s;
      width: 12px;
     details > summary:after{
    transform: rotate(-45deg);
        right: 2px;
        transform-origin: 50%;
     details > summary:before{transform: rotate(45deg);right: 10px;transform-origin: 50%;}
    details[open] > summary:after {
    details[open] > summary:before {
  • Thank you very much. It works well, but I tweaked it a little and came up with this CSS. What do you think? Can it be used, or is there something wrong with it?
    .toc-wrapper details > summary {
      list-style: none;
      position: relative;
      cursor: pointer;
      padding-right: 2rem;
      font-weight: bold;
      user-select: none;
    /* Skrytí markerů */
    .toc-wrapper details > summary::-webkit-details-marker { display: none; }
    .toc-wrapper details > summary::marker { content: ""; }
    /* Plus symbol */
    .toc-wrapper details > summary:before {
      content: "+";
      position: absolute;
      right: 0.5rem;
      top: 50%;
      transform: translateY(-50%);
      font-size: 1.4em; /* Větší pro lepší viditelnost */
      font-weight: bold;
      line-height: 1;
      transition: transform 0.3s cubic-bezier(0.4, 0, 0.2, 1);
    .toc-wrapper details[open] > summary:before {
      transform: translateY(-50%) rotate(45deg);
  • Looks good 🙂
  • Last question 🙂 Should I put the CSS in the template or rather in the elements and only insert it into posts where the TOC will actually be?
    Thank you
  • I would add it to cstomizer > addtional CSS, so it can be loaded before HTML gets loaded to avoide layout shift issue.
  • Unfortunately, I have now discovered that the problem with {{post_permalink}} is caused by the SimpleTOC
    https://generate.support/topic/carousel-query-problem/page/2/#post-188457
