SimpliCloud Layout Broken
    I tried using the SimpliCloud site demo, however the layout is broken. Any ideas?
    Thanks,
    Matthew
    do you have GenerateBlocks Pro installed and active on the site?
    As its a requirement for that site, and I believe it should only allow you to install the site if that plugin is present.
    Let me know.
  • I have GeneratePress Premium. It allowed me to install the demo. However the functionality is broken. Is there a way to fix it or is the only option to purchase GenerateBlocks Pro?
    Thanks,
    Matthew
  • Hmmm… I’ll take a look into that, as it should only allow install if the GenerateBlocks Pro plugin is present.
    And the only option to use the site is with GB Pro. As its built with Patterns that use the GB Pro Global Styles.
  • Ok thanks for looking into that. In order to upgrade GenerateBlocks Pro, is there a way for me to only pay the difference between Premium and Pro?
  • If you follow this link:
    https://generatepress.com/support/
    And then raise an Account / Billing ticket, one of our accounts team can let you know what options are currently available.
  • Ok will do thanks.
  • You’re welcome
