Stefanie
Hi team,
Since I still prefer to use the “old” site header, I created a global class a while back to format the class
inside-header. It’s always worked fine until now, but suddenly it’s not working anymore, and I don’t know why.The menu items no longer have the same width as the content (global-width). https://ibb.co/YvQBkXN
What do I need to do to make them line up again?
Thank you!
George
Try Customizer -> Layout -> Container -> Container Alignment, set it to
Boxes.
Stefanie
Hi George,
Thanks for your quick response.
I’ve set it up the way you suggested, but unfortunately it hasn’t made any difference. -
Stefanie
Hi again,
I suspect the problem is that the padding is applied to the outer container in the content sections, whereas in the old header (or the “inside-header” class), the padding is applied to the inner container.
But I’m surprised… it used to work. I don’t understand why it doesn’t anymore.
George
Strange. Can you please provide credentials in the private section so I could have a look? You can also install the Temporary Login Without Password plugin and send us a login link without using a password. Again, please, use the private area of your reply to send those details.
Stefanie
Thanks for your offer. I was able to solve the problem on my own.
I’ve now modified theinside-headerclass, and it’s working.Best,
Stefanie -
George
Ok, no problem!
