I created site header and navigation blocks first time.
I used old menu. But sub items are not openning on the right side like before.
It is just openning in the main menu column. -
I’m not sure what you mean, do you want something like this?
https://app.screencast.com/s60TBSL0qiAtO -
Hi thanks for reply.
clikc bütün ürünler > laptop then you will see another 6 lines as sub menu. It was opening in the right side before. Now opening in the same main column.It should be like original menu in my other websites, which I didn’t apply for site-header block yet.
I added more images -
George
Hi Ned,
The nested sub-menus are inheriting
left: 0from the base styles, which places them at the same position as the first level instead of flying out to the right. Add this to Appearance → Customize → Additional CSS:.gb-menu--base .gb-sub-menu .gb-sub-menu { left: 100% !important; top: 0 !important; }That should give you the flyout behaviour you’re after.
Hi George,
Thanks, I will try. But can I add these css via block settings in navigation block? -
George
