irene1
I have also uploaded a screenshot to postimages
https://postimg.cc/rKfdNXwn link address
George
Hi Irene,
Nothing in that Site Health report relates to GeneratePress or GenerateBlocks — it’s all server and caching configuration, so I’ll point you in the right direction rather than leave you guessing.
The two critical items:
Outdated PHP (8.0.30) — this one is worth acting on. PHP 8.0 stopped receiving security updates in November 2023, and 8.0.30 was its final release. Ask your host to move you to PHP 8.2 or newer. This is a host-side change, not something done from within WordPress.
Page cache detected but response time still slow — your median server response was 707ms against a 600ms target. That’s a hosting performance matter. Moving to a current PHP version often improves it on its own, since newer versions are considerably faster. If it stays slow afterwards, your host is the right place to raise it.
On the 11 recommended improvements: most of those (Cloudflare integration, CSS/JS concatenation, critical CSS, lazy loading, deferred JavaScript) aren’t WordPress core checks — they’re added by a performance plugin you have installed, and they’re that plugin’s own feature checklist rather than genuine problems. You don’t need to enable all of them, and enabling CSS/JS concatenation or deferral without testing can break layout or scripts.
Two that are genuinely worth doing: remove the inactive plugins and themes (unused code still needs patching), and ask your host about the outdated SQL server version.
Was there something specific going wrong on the site that prompted this, or were you mainly asking about the warnings themselves? If you’re seeing an actual problem — layout, speed, something not displaying — let me know and I’ll take a closer look.
