Site Library Import has wrong URL’s for buttons
  • Hi Support,
    When importing from the Site Library, most of the Buttons and Images are still linked to your sites.generatepress.com site. This is confusing for clients after they import a template and play around, being redirected to your site.
    For example, the Keynote Speaker template from GP One.
    Can you please fix this? It’s a lot of effort to run DB Search & Replace for each site I am setting up. I do understand that not all images are imported (some are, so why the inconsistency?). But the links should point to the correct subpage.
    I appreciate your support.
    Thanks,
    Patrick
    You will need to manually update the links, unfortunately!
    Due to the multi-site environment and permalink structure of the site library, we can’t use relative links in the site templates, so we can either use empty links or absolute links.
  • Hi Ying,
    Okay, thanks for your fast reply.
    Best
    Patrick
  • You are welcome   🙂
  • I just had the same “problem” and fixed it with a quick “search and replace” for the link. With this, you can change all the links into your URL in one step.
