johnottomagee
Hello Support Team !
I want to make changes to UC’s layout.
https://understand-culture.com/There is only one navigation.
It is at the the top of the page.
I want to move it to the left-hand side.I have created a staging site.
It has been a long time since I designed UC,
and with your great help.I tried to make some changes, but quickly got lost.
Then I realized that there is a lot of CSS on the site.
I suspect that I am limited in the changes I can make.Please advise me on how to proceed.
Thanks !
John
Hi John,
Have you tried this example 7 which I recommend in your other topic?
https://docs.generatepress.com/article/header-examples/#example-7To make it work, you need to disable the Use navigation as header option at customzier > layout > header, and set the primary navigation location to float right at customizer > layout > primary navigation.
Then add the CSS.
Let me know if this works!
johnottomagee
Thanks, Ying.
I’ve decided to rebuild
UC from the bottom up.I have a staging site.
I’ll delete all CSS.I want a super-simple site.
See ChatGPT and Perplexity.UC should look similar.
Semantic-search box in the middle.
A few menu items on the left.John
The topic has been marked as resolved. Do you still need help with the sidebar style menu?
