Site Title Doesn’t Appear In Mobile
  • My wife’s site https://mishaminoff.com shows the site title Mish Aminoff Photography in desktop and tablet display mode. But in mobile, the title doesn’t appear.
    I have checked Appearance/Customize/Site Identity, and the settings are the same for desktop, tablet, and mobile.
    Can you please help me get a title showing on the site’s mobile presentation?
    Go to customizer > layout > header, and disable the mobile header.
    To manage the sizing of the header on mobile, you can reduce the mobile paddings of header by clicking the mobile icon.
    Let me know if this helps!
  • I am sorry, no that doesn’t solve it.
    As an aside I notice that the mobile paddings of the header are blank, and adjusting them makes no difference.
    It was the cache plugin causing the header on mobile not to appear. You need to check your cache configuration and ensure it is set up properly.
  • Could you tell me what I need to change in my cache configuration please?
  • Try to disable the cache plugin to see if the change saves. Also check if you have server level cache enabled, if so, clear that or disable that to test.
    As for cache plugin configuration, it’s not something we can advise as every cache plugin has different settings. I would recommend checking with the plugin’s support.
