Dominic_
While working on a site I noticed that when creating a block element on a custom hook, slashes in the hook name get removed during sanitization. This breaks compatibility with commonly used hook namings.
Example:
- Input:
my_plugin/group/stuff - After sanitization:
my_plugingroupstuff
Problem:
Thesanitize_custom_hook()function usessanitize_key(), which strips slashes.Is there any particular reason for such a strict sanitation?
Also: Is it save for us to manually update the post-meta
_generate_custom_hookto the correct hook-name, or is it stored somewhere else too?Thanks!
Best
Dominic - Input:
it’s a legacy thing and not something we have had any call to change. I will raise an issue to see if we can fix this.
Updating the post meta; “should” work although I have not tested.
Alternatively the
sanitize_keyhas a filter. And you could do something like this to bypass the filter just for you “prefixed” hook:add_filter( 'sanitize_key', function( $key, $raw_key ) { // Only target GeneratePress custom hook identifiers if ( strpos( $raw_key, 'my_prefix/' ) === 0 ) { return $raw_key; // preserve slashes } return $key; }, 10, 2 ); -
Dominic_
Hi David,
thanks for the fast clarification!
Updating the value in the DB worked for now and it doesn’t seems to be referenced somewhere else.Best
Dominic -
Glad to hear that!
