Slide mobile menu was not working – had to check “Off canvas menu”
    Today I realized that my hamburger mobile menu slide was not working opening on a blank slide and throwing the following error:
    Uncaught TypeError: Cannot read properties of undefined (reading 'focus') at offside.min.js?ver=2.4.1:1:4221
    I discovered that ticking the option “Off canvas menu” in the menu options solved the problem.
    I don’t know how long this problem has been going as I don’t check the mobile menu of my website often. Are there recent changes to GP or GP Premium that might explain this?
    Thanks.
    Nicolas
    No reason changes in that file, but I’m experiencing the same thing if my Off-Canvas panel is empty. However, it still opens and closes without any issues.
    Was there a particular reason you wanted your Off-Canvas Panel to be blank/empty? Or was this issue happening even with contents inside of it?
  • Thanks,
    That’s because I had never noticed this “Off-Canvas menu” option (or I forgot about it since I started using GP Premium 3 years ago, cannot be sure as I never have a look at my menu options). My mobile slide menu had always functioned properly. Has this tick box been around for a while?
    I recently cleaned my wp_options table for old unused plugins. Could I have lost this parameter upon doign that (though I tried to be careful).
    Nicolas
  • Has this tick box been around for a while?
    It’s always there.
    It’s hard to tell if it’s related.
  • Thank you,
    I restored some backups of my website and was pleased to see that on August 29th backup, the off canvas menu box was ticked (the slide mobile menu worked) but not on August 30th (so I hade only 3 days of non working mobile menu I was fearing longer).
    So that means that I changed something on my site between these two dates but I’m sure I haven’t touched this “Off-Canvas menu” option.
    True I did lot of debugging for another plugin with a lot of plugins and theme deactivation. But that shouldn’t cause a change in GP Premium options.
    Tried to retrace what I have down on my website between those two dates, from memory, on the August 29th backup to recreate the “unticking” of the box, but to no avail.
    So case closed for me.
    Best.
  • Glad to hear you managed to find a resolution!
