slide-out menu for mobile loads 3 menu
  • When I use the slide-out menu on mobile, three menus are loaded:
    Desktop (150), Mobile (150), and the slide-out menu (40).
    How can I prevent the mobile menu from loading as well when I use the slide-out menu?
    Is it possible to see a URL?
    I can see that on mobile, only the slide-out menu is loading. Am I missing something?
    Slideout menu
  • That’s right—you only see one menu, but three are actually loaded.
    The desktop menu loads 115 links, the mobile menu loads 116 links, and the slide-out menu loads 41 links.
    Instead of 156 links, 342 links are loaded, which unnecessarily increases the size of the HTML file.
  • To avoide loading 3 menus, you need to disable both the mobile header and the slide-out navigation; otherwise, it’s inevitable.
