akashkumar
Dear GeneratePress Support Team,
I hope this message finds you well. I am currently customizing my website using the GeneratePress theme and need your assistance with two specific features:
Blog Slider: I would like to create a blog slider similar to the one shown in the attached image (Image1.png). The slider showcases the latest book summaries with the following features: https://readersbooksclub.com/
Display of book cover images – https://i.postimg.cc/Bb6XQzj3/Slider.jpg
Titles and read times for each book summary
Navigation arrows for sliding through the content
A responsive design that works well on both desktop and mobile devices
also slider on mobile view should be same as the referred websitePost Hero Section: I also want to design a post hero section like the one shown in the second attached image This section includes: https://readersbooksclub.com/12-power-principles-for-success/
A large book cover image on the left – https://i.postimg.cc/9X8DNckQ/Post-hero.jpg
The title of the book and a brief description on the right
Author name, read time, categories, and additional tags below the description
Could you please guide me on how to achieve these features using GeneratePress? I am open to using additional plugins or custom CSS if necessary.Thank you for your assistance.
we don’t have a Slider option for Displaying Posts.
For now you would need to use a dedicated Post Slider plugin to do that.The single post hero you can build using a GP Block Element – Page hero:
https://docs.generatepress.com/article/block-element-page-hero/
Set the elements Display Rules Location to:
Posts
>All Posts
Use the GenerateBlocks Plugin to build the layout and add the dynamic data.
For the base layout you would create:
Container Block #1 ---- Container Block #2 ---- ---- Container Block #3 Left column ---- ---- ---- Image Block ---- ---- Container Block #4 Right column ---- ---- ---- Headline blocks for title ---- ---- ---- Headline blocks for description ( Excerpt ?) ---- ---- ---- Container Block #5 for Post Meta row ---- ---- ---- ---- Button blocks for post meta
Container Block #2
Set the Sizing > Max Width to Global Max Width by clicking the blue globe icon
Set the Spacing > Margin Left & Margin Right toauto
Set the Layout > Display to Flex, switch to Mobile view and set the Display to BlockContainer Block #3 & Container Block #4
Set the Sizing > Width to the % you require eg. 50% for each column or 40 / 60….
Switch to Mobile view and set the Width to 100%GB Image Block
In the GB Image Blocks settings activate the Dynamic Data and set the Content Source to Featured Image.Blocks inside the Right Column,
Here you would need to add the headlines for the Title and Description ( Post Excerpt ? )Container Block #5
Set the Layout to Display Flex and Flex Wrap to Wrap
Within this container you can add the Button blocks and set there dynamic data to show the Post Author and the List of Terms.For the Reading Time you will need to create a shortcode to display that. See here:
https://generate.support/topic/reading-time-with-generateblocks/#post-86125 -
akashkumar
Hi David,
Thanks for earlier.
I have created a single post element for my blog posts. – https://postimg.cc/nXjLZ9yN
but I am facing some issues with it
My content is not in the middle. If I see my blogs on a larger screen, it is shifting to the left side. It should be in the middle.
Please help me with this and I am not into technical kinds of stuff and I also don’t have much code knowledge.Thanks.
Edit your single post block element content template.
And open the List ViewExpand the top Container Block and select its inner Container.
Set the blocks Spacing -> Margin Left & Right toauto
That will center that container for your.
akashkumar
Hi Devid, thanks, it worked!
now i need Reading time in my single post element. – https://postlmg.cc/Cd8MRpY3
it should fetch the reading time automatically.
please help me with this also as I mentioned earlier that I am not into technical kinds of stuff and I also don’t have much code knowledge.Thanks.
1. Add this PHP code to create a shortcode
[reading_time]
.add_shortcode( 'reading_time', function() { ob_start(); $post = get_post(); $content = $post->post_content; $wpm = 238; // How many words per minute. $clean_content = strip_shortcodes( $content ); $clean_content = strip_tags( $clean_content ); $word_count = str_word_count( $clean_content ); $m = ceil( $word_count / $wpm ); if($m < 2) { $time = '<div class="reading-time"> 1 min</div>'; } else { $time = '<div class="reading-time"> '.$m . ' mins</div>'; } echo $time; return ob_get_clean(); } );
2. Add the shortcode
[reading_time]
via a headline block in your element. -
akashkumar
How to add this PHP code exactly?
Also, please elaborate on adding shortcode via headline block.Thanks
This article provides methods on how to add the PHP:
https://docs.generatepress.com/article/adding-php/Also, please elaborate on adding shortcode via headline block.
After adding the Headline block, just type in the shortcode name with square brackets, like this: [reading_time]
