slotting advertising banners directly into post content
  • Can you please share any ideas you might have using Generate Press or Generate Blocks to individually slot a series of ad banners directly into post content?
    We have 6-7 different sponsor banners that we currently show as a batch below posts using an element. But they only get seen by scrolling past the content.
    I’d really like to be able to show individual ads within the content of a post. But I’d also like to do so without having to manually slot a shortcode or manual html into a post each time.
    Is there a way to 1) non-manually slot ads directly into post content and 2) have the ads set up to appear in some kind of rotation?
    The easiest way would be using a plugin like Ad inserter to insert your custom content inside the regular post content.
  • I saw that before I emailed in to GP. I was hoping to stay away from yet another code-heavy plugin. But it does do what I described. Thanks.
  • No Problem 🙂
