harveym9
Hi guys,
I didn’t like the default indentation for lists on generatepress on mobile (the indent is massive, forcing text to wrap too much), so I changed the CSS on mobile to remove the left margin using,
ul{ @media(max-width: 768px) { margin-left: 27px; } }
This has got my in-article lists looking spot on, but has effected the pros/cons custom block (only on mobile) I’ve setup using GenBlocks,
I’ve corrected the first product’s pros/cons block, but all the other ones across my site are now like this. See the rest of this article for examples: https://a1athlete.com/best-vertical-jump-programs/
I was wondering if you could find me the CSS class for the Pros/Cons container so I can quickly add some CSS to fix the mobile indentation in these blocks across the site?
Thanks so much <3
Hello Harvey,
To clarify, do you want to decrease the space within the dot and the text or do you want to decrease the space before the dot?
harveym9
Hey mate, I wanted to decrease the indentation of the default lists on GPress… and I’ve done that. But now I want to reverse it for the Pros/Cons block, so shift the text to the right (so that it’s inside the box).
Try replacing the code you have with this:
@media (max-width: 768px){ .entry-content ul:not(.post-content){ margin-left: 27px; } }
harveym9
That didn’t work unfortunately, it’s also reset the regular indentation to the default:
To confirm, I want the modify the above indentation, not the indentation in the GenBlock.
Cheers
How are you adding the CSS? Do you have an optimization/caching plugin? Can you disable that first?
harveym9
I’m just using the Additional CSS in Customize.
Note your solution DID change something on the page (it pulled the Pros/Cons text back into the box, which I wanted), but it also pulled the normal lists back to their heavily-indented position.
So I’m pretty certain caching isn’t the issue.
For reference, can you take a screenshot of a list it’s not working on but should?
harveym9
Yeah I included one earlier but here’s another (on that same page),
It should work on that. See: https://share.getcloudapp.com/v1uPkqjO
I’m thinking there’s a Syntax Error somewhere on all your CSS. I was going to check but I can’t see the CSS on your site which is why I was asking to disable caching/optimization plugins.
harveym9
Oh my bad man, I had the @media tag inside of a ul{}, so I removed it and it works perfectly.
You’re a G, Fernando!
You’re welcome, Harvey!
