Small issue with a Mega Menu
  • I’m trying to make a simple Mega Menu – a bit similar to the Product mm on the GP website (not necessarily 2 x 2)
    I have it working mostly how I want it, but when I hover over one of the 3 items there is a slight movement to the right of the container, I can’t work it out..
    Also the container for each of the three has a bit too much padding – top/bottom, again, can’t work out where that is configured.
    The link to my play site is below!
    And the MM is on the Services main menu using the Mechanic starter site!
    Thanks, Dave
  • Hi Dave,
    Select the menu item wrapper, then edit the gbp-mega-menu__link global style. Switch to the Hover selector and either remove the border setting or reduce the border width to 0.5px — that seems to be causing the issue.
    For the top and bottom spacing, select the text block inside the menu item and set its bottom margin to 0.
