Smooth-scroll not working
  • Hi!
    With the new release of GB and GP I can’t get the smooth-scroll to work. Is there something I am missing here? Look at the page in the private info and the section “Snabblänkar”. Thanks!
    Best,
    Johan
    The smooth-scroll class needs to be added to the a element, you are currently adding it to the text span.
    Try to use this PHP to make all anchor links smooth scroll. You can remove the smooth scroll class from the headline block 🙂
    add_filter( 'generate_smooth_scroll_elements', function( $elements ) {
        $elements[] = 'a:not([data-gpmodal-trigger="gp-search"])[href*="#"]';
        return $elements;
  • Works great! Thanks!
  • You are welcome   🙂
