Smooth Scroll Stopped Working
  • I use GeneratePress, and I have added the code:
    //remove GP smooth scroll from back to top button
    add_filter( ‘generate_back_to_top_js_args’, function( $args ) {
    $args[‘smooth’] = false;
    return $args;
    This was working fine, and now it is moving very, very slowly. I deactivated all plugins besides Elementor Pro and GeneratePress Pro. Still does not work correctly.
    The code should still work.
    How did you add the code? Is there any other custom PHP code on your site?
  • Added to the child theme files and that is the only php added. Code is still there but stopped working. I tried deleting and readding also.
  • I just tested the code, and it’s still working fine.
    Can you share your admin login?
  • See below
  • You’ve added the code the style.css file…
    It should’ve been added to the functions.php file.
  • Thank you! It is a very Monday Tuesday.
  • You are welcome   🙂
