LSiegel
A couple of items on this page:
Navigation – when resizing between these breakpoints, alignment of the nav shifts a bit. In inspector mode, when opening the toggle nav, no menu is present for Surface Pro 7. The Proven results section is also not as expected – looks like desktop and not tablet view even though editor for tablet is correct. Had to add some custom css for the results column displays to override defaults. -
the issue is caused by an overflow issue, and the overflow issue is caused by your custom CSS:
.gb-carousel { clip-path: inset(-4px 0 -4px 0) !important; overflow: visible !important; }Can you delete the second line of the CSS to test?
LSiegel
added custom css to address items, but notice that tablet doesn’t seem to cover FULL tablet range in some cases with grid or column block especially.
Not sure what you mean, can you point me to where I can see the issue?
LSiegel
Thank you
