forexjoustar
I have built a site however, on one of my pages, there is a gap between the footer area and the body. If you scroll to the bottom, you will see the white gap between the 2 blue areas (footer and body). How do I remove this?
Hello there,
Remove the Separating space and the Bottom padding on Appearance > Customize > Layout > Container.
Reference: https://docs.generatepress.com/article/container-layout-overview/
forexjoustar
It has made an improvement but even when Content Padding Bottom is set to 0, there is a small gap.
Based on your site design, you should be using one container layout instead of separate containers.
Can you go to customizer > layout > container > Content Layout and change it to one container?
forexjoustar
That appeared to remove the gap however, the other elements on the page, including the top menu shift positions. Is there a way to only allow the gap to be removed without anything else getting affected? I can provide you admin details if you like.
You can set it to
One Container
and then add top padding to the Container.Or, you can try adding this through Appearance > Customize > Additional CSS:
.separate-containers .site-main { margin-bottom: 0; }
