sydneyc
Hi
I have 2 small spaces on my homepage I’d like to eliminate. They’re each underneath a photo.
I used Footer Widget #3 and can’t seem to get the headline and the grid below it to align properly.
To fix the space underneath the photo issue, select the Image block and set its Display to Block.
For the Footer Widget issue, try building the Headline and the Grid within the same block inside the widget, instead of using separate blocks. This should give you better control over the alignment.
sydneyc
THANK YOU!! This worked for footer but for the life of me, nothing I’m trying is getting the links underneath “take a look around” to center
It looks centred to me:
https://app.screencast.com/sXuxdhQWz3eyI -
sydneyc
On desktop it’s centered, but not on mobile. Sry forget to specify mobile
It’s ok, it looks centered on mobile as well:
https://app.screencast.com/Q9LqG2PZEoaE3
