Spacing issues
    Since updating my generatepress theme last week, i have noticed spacing issues in majority of my posts on the front end.
    the first spacing issue is that there is no gap between the first image in my posts and the table of contents, whereas before there was a gap.
    also, throughout the content in my posts, i have added quite a number of spacer blocks between sections, usually underneath each image and before the next heading in the post, however, this gap is not showing on the front end.
    I have attached an image to see the issue
    TIA for the help 🙂
  • Hi Jonny,
    The update shouldn’t have caused that.
    Did you update WordPress as well? WordPress had a recent update that caused issues like these.
    You can try adding this through Appearance > Customize > Additional CSS instead:
    figure.wp-block-image {
        margin-bottom: 16px;
    This add a bottom margin for WordPress images.
