Star ranking shortcode not working as intented in my archive loop
  • I have implemented a shortcode, which can be found here, to display a 1-5 star rating based on a custom post_meta field created with ACF. I integrated this shortcode directly into my functions.php file by modifying the $rating = get_field(‘MY_ACF_CUSTOM_FIELD’) variable.
    In order to showcase the star rating in my archive query loop element, I included the shortcode [star_bar]. However, it appears that the dynamic value retrieved is always coming from the first post. Please check my screenshots for more context.
    What could be wrong?
    Thanks.
  • Hi Jinigoe,
    Shortcodes will always return the get value of the page viewed on a Query Loop.
    You’ll need to filter it in.
    Can you try creating a Container Block and give it a class of: cu-star-placeholder. Adding Custom Classes: https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/
    Then, add this snippet:
    add_filter( 'render_block', function( $block_content, $block ) {
        if ( !is_admin() && ! empty( $block['attrs']['className'] ) && strpos( $block['attrs']['className'], 'cu-star-placeholder' ) !== false ) {
    		$rating_term = get_field('rating');
    		$star_color = 'orange';
    		$prefix = 'star-bar-';
    		$uniqueClass = uniqid($prefix);
    		$percentage = 100 * $rating_term / 5;
    		$html = '<strong>'.$rating_term.'/5</strong>
    		<span class="'.$uniqueClass.'">★★★★★</span>
    		<style>
    		.'.$uniqueClass.' {
    			background: linear-gradient(90deg, '. $star_color . ' ' . $percentage .'%, rgba(0,0,0,1) '. $percentage.'%);
    			color: rgba(0,0,0,0);
    			background-clip: text;
    			-webkit-background-clip: text;
    		</style>
    		<script type="application/ld+json">
    			  "@context": "https://schema.org",
    			  "@type": "Rating",
    			  "ratingValue": '.$rating_term.',
    			  "bestRating": "5",
    			  "worstRating": "1"
    		</script>
    		return $html;
        return $block_content;
    }, 10, 2 );
  • Thank you so much! Adding a filter did the trick!
  • You’re welcome, Jinigoe!
