Starter Site: App
  • Hi, the starter site “App” is gone. What has happened? Thanks, Uli
    The site is not in the list of sites that will be converted to v2 GB blocks.
    It’s still in v1, if you don’t mind, you can use this PHP code to revert to v1 block, and go to the site library, scroll to the bottom, click the Refresh sites button, you should be able to import the v1 App site template.
    After importing the template, you can remove the PHP snippet.
    add_filter( 'option_gb_use_v1_blocks', '__return_true' );
