static homepage hero issue
  • Hi, Support team,
    I just switched from Marketer to Volume which is quiet differnet form the former, and I find I love Single Post Hero, and build an homepage hero element with Single Post Hero, but I could not find the display rules and set location. In All pages, I have a homepage already, is it conflict with homepage hero element? Given this, I removed the said element, and try to set my homepage as a static page as in Marketer which I have been using for all long time, but found no way to add a hero block just like volume’s default Single Post Hero.
    Please clarify how can I fix it.
    Regards
    No, having a homepage page won’t conflict with a hero element. The hero only shows where its Display Rules tell it to.
    For Block Elements, the Display Rules are in a box at the bottom of the editor, not in the right sidebar. Look for the “Meta Boxes” bar at the very bottom of the editor screen and click it to expand it. The Location, Exclude and Users settings are in there.
    Volume’s Single Post Hero is set to Post > All Posts and is built for single posts. It pulls the post title, excerpt, author, date and featured image automatically. To make a similar hero for your static homepage:
    – Go to Appearance > Elements and open the Single Post Hero element.
    – Click the three-dot menu at the top right of the editor and choose Copy all blocks.
    – Go to Appearance > Elements > Add New, choose Block, then set Element type to Page Hero in the right sidebar.
    – Paste the blocks into the editor.
    – Replace the title and excerpt with your own text, and remove the “Written by / Published on” row since it doesn’t fit a homepage.
    – Expand the Meta Boxes bar at the bottom and set Location to Front Page.
    – Publish the element.
    The background image comes from the page’s featured image, so set a featured image on your homepage, or replace it with a fixed image in the Element block. You can also turn on Disable title in the right sidebar to hide the page’s own title under the hero.
    Let me know how it goes!
  • NO, do not work as usual.
    In fact, I indeed done what you described, but failed, which confused me.
    One important clue is all heros I added from library default heroes do appear correctly at frontend.
    Given this, I believe something wrong with the setting of the copied block.
    Please clarify what I should do next.
    Regards
  • Would it be possible for you to provide temporary admin access to your site so I can take a closer look? That way I can better understand your current setup and provide more specific instructions.
    You can share the login credentials in the Private Information section so that only our support team can access them.
  • thanks a lot
  • The problem is due to the root container in the element having a dynamic background image set to the featured image and having the Required to render option ticked, which means if there’s no featured image for this page, the entire container will NOT show.
    Here’s a screenshot for your reference:
    https://app.screencast.com/6KWPqYyOgDpFP
    Simply remove the dynamic background image for the root container should fix the problem.
  • thanks, but how to remove the background image, I find no option as your documentation described, what’s wrong with it. My Generate block version is 2.5.
  • You just need to delete the dynamic tag from the inline background image field (the highlighted area is in the right sidebar in my screenshot).
  • Thanks, Ying, works well now.
    I always use Marketer, just switch to Volume to do a test.
    I found lots of differences, still need you and your team’s further assistance later.
    Regards
  • No worries, we are here to help 🙂
    Glad it works now!
  • One more question:
    I disabled post author, but “written by” still appear, this is quiete different form Marketer, really confused me.
    plese clarify it.
    Regards
  • If you want to remove the entire written by section, you need to remove the entire text block:
    https://app.screencast.com/ukv3dzo85Qc7m
  • Thanks, written by container removed, works well.
    The current block editor is more powerful than classic editor which I’m used to.
    I’m adapting myself to it quickly since I’m able to use classic one smoothly.
    The default elements are wonderful. In general, I can set it up for desired results.
    One more:
    Please clarify how I can make homepage hero exactly as the the single post hero, i.e, where I can control it. Please check both urls of them.
  • Please clarify how I can make homepage hero exactly as the the single post hero, i.e, where I can control it.
    Your Home page doesn’t have a featured image. The Single Post Hero uses it as the background, and without it the hero doesn’t show.
    1. Go to Pages > Home, set a featured image, and click Update.
    2. Open the Single Post Hero element, click the three-dot menu at the top right and choose Copy all blocks.
    3. Open the Static Homepage Hero element, delete all its blocks, then paste.
    4. Change the title and the description to your own text.
    5. Delete the “Published on” row, then click Update.
    From then on, you change the background image by changing the Home page’s featured image, and you edit the text in the Static Homepage Hero element.
  • Thanks, Alvind
    Works well.
    Yes, I have not added featured image, also not set Inline Background Image value.
    Oner more:
    Please check url I just put in private area to clarify how I can image info appeared incorrectly next to the image. I have never seen such an error at frontend with regard to Marketer.
    Regards
  • Glad to hear that 🙂
    The text next to the image comes from the post content, not the theme. A link was added inside the image’s alt text, which breaks the image code, so part of the description shows on the page.
    To fix it:
    1. Edit the post, click the three-dot menu at the top right and choose Code editor.
    2. Press Ctrl+F (Cmd+F on Mac) and search for: alt="Tahitian <a
    3. On that line, delete the <a href="https://en.wikipedia.org/wiki/Pearl" target="_blank"> part and the </a> after “pearl pendant”.
    4. Click Exit code editor, then Save.
    These posts have the same issue. Use the same steps with the search text next to each:
    – /black-tahitian-brilliance-for-the-wrist/ – search for South Sea <a
    – /peralpow-pearl-powder-benefits-skin-eyes-heart-bones/ – search for alt="Organic <a
    – /what-if-lara-trump-paired-her-qipao-with-pearls/ – search for floral <a
Viewing 16 posts - 1 through 16 (of 26 total)
