Sticky bar after header
  • Hello
    How can I add a sticky bar after the header but without created a “blank” between the header and the beginning of the content ?
    The bar will be just after the header (both in desktop and mobile) and above the content. Even in scrolling
    If I’m using a hook ‘after header’ and make it position-sticy, it’s ok after scrolling but at the beginning, there is a blank
    Is there a way to do this with GP/GB ?
    Can I see your site with the solution implemented?
  • Hi Ying
    thanks for your reply. Unfortunatly the site is yet in Figma’s conception, I just make some tests in a local staging site. ^^;
    I’ve come with this code :
    .bar {
      position: fixed;
      top: 80px;
      left: 50%;
      transform: translateX(-50%);
      width: 100%;
      z-index: 1000;
    But I would like this code only on homepage and this one for other pages :
    .bar {
      position: absolute;
      top: 80px;
      left: 50%;
    My element is hooked “after_header”.
    May I do this two configurations without creating two elements ? (I’ve tried whith a Css’ selector like ‘.home’ or body:not(.home) but like my element is placed on all site, it does not work perfectly. And I would like only one element because I will have to change some text periodically)
    in your Element add Container within a Container eg.
    Container Block #1
    ---- Container Block #2
    ---- ---- Your top bar in here
    Container Block #1 set its Position to Sticky.
    Container Block #2 set its Position to Absolute
    This will make the second container and its content take up no space on the page. But it will remain attached to the sticky container
