I tried to follow some tutorials like here and there but I’m sorry it still isn’t working and I don’t understand why.
In the private box you can find a URL with a grid and I let the different classes in the different containers to help.Could you please help me ? And if possible, could it stay sticky when reaching the center of the screen when scrolling.
Thank you
for illustration lets assume you have a 2 column grid:
Grid Block ---- Container Block #1 ( left column ) ---- ---- Container Block #1.1 for sticky content ---- Container Block #2 ( right column ) ---- ---- Other content.
1. make sure the Grid Blocks vertical alignment is set to Default
This will make both columns Container Block #1 and #2 a Height of 100%2. select Container Block #1.1 for the sticky content.
2.1 Create a new Global Style:
https://docs.generateblocks.com/article/creating-a-global-style/Call it
is-sticky
for example
Start with a Blank Style2.2 in the global styles Position panel , set the Position to Sticky and then the Top to
0
or any value eg. 50px.
The value add will determine the space above it when its sticky.3. Update the post to save the Global Style.
Thank you David I’ll get to know more about the Global Style as I don’t use it a lot.
Unfortunately for the website I’m working on I don’t have GenerateBlock Pro, just the GeneratePress Premium.Would it be possible to use CSS please ? In the private box I added an URL for the image to check if this is correct
Thank you
The same setup, but instead of adding the global style do this:
1, select Container Block #1.1 and in Advanced > Additional CSS Classes just add is:
is-sticky
2. then add this CSS to your site:
.is-sticky { position: sticky; top: 0; }
Make sure to clear any caches afterwards
I found out the problem. So I was doing it right since the beginning but I tried on 2 different websites and it wasn’t working because I have this CSS which apparently was blocking the sticky to execute
html, body {overflow-x: hidden;}
Edit : I added
@media (max-width:768px)
to it and now the sticky is working on computer screenThank you
Ah yes, the
will break sticky position.
Glad to hear you got it working.
