Sticky container now working on front end
  • Hello GP team, I have an issue with a sticky container in a sidebar I am trying to make for the post site.
    I think all my settings are correct because it works normally in the editor, but it is not showing on the front end for some reason. I tried clearing the server cache and it didn’t fix the issue.
    The outside container is full height so that shouldn’t be an issue.
    The inner container is position:sticky
    I put the site in the private info 🙂
    It’s because you have this CSS:
    body, html {
        overflow-x: hidden;
    and when GP’s slide out nav is enabled, GP adds this CSS as well.
    .offside-js--init {
        overflow-x: hidden;
    Both CSS prevent the sticky element from working.
    So change #1 CSS you added to this to override GP’s CSS:
    body, html {
        overflow-x: initial !important;
  • Thank you Ying, works perfectly! I didn’t know overflow prevented sticky from working.
    I will mark the thread as resolved 🙂
  • You are welcome 🙂
