Sticky element disappears when triggering modal
  • I’ve used the code below to prevent body scroll when the modals are open. But this makes the sticky bottom element I have on the page (the one with the price and the red button) not to be sticky anymore. It simply goes to the bottom. Any idea how to fix this? Thanks.
    :root:has(.bod-block-popup-wrap.active) {
        overflow:hidden;
    The sticky element won’t work if any of its ancestor element is set to overflow:hidden.
    Try using a more specific CSS selector instead of :root.
    Or you can change the sticky element from position: sticky to position:fixed.
  • Fixed instead of sticky seems to do the trick. Thanks so much, Ying.
  • You are welcome   🙂
