robertschmidt
I would like to enable the sticky header and the header search. However, when I do this it seems to break in production. The search shows up with an x next to it and it is linked to #, which takes me to the bottom of the page. Not what I want. Also, the entire sticky header itself shrinks and shifts after scrolling.
I suspect this has something to do with WPRocket. In WPRocket I’ve tried excluding:
/wp-content/plugins/gp-premium/menu-plus/functions/js/sticky*.js
But this did not work.
Is the sticky header not compatible with WPRocket? Or am I missing something else here?
If you don’t want the transition of the sticky nav, you can use simple CSS solution, so no JS will be loaded.
If you can provide your site link, I can write the CSS for you.
robertschmidt
Sure, included the site below.
Try this CSS for sticky header:
.site-header, #mobile-header { position: sticky; top: 0; z-index: 1000; }The search issue is weird. can you disable all plugins except GP Premium to test?
robertschmidt
I added the css and it is not working. I see if I can disable all plugins on staging.
How did you add the CSS?
robertschmidt
I put it into simple css.
I inspected your homepage, and the stylesheet of Simple CSS is empty, which means the CSS hasn’t been added in.
https://app.screencast.com/vv5iCUC49HJenDo you have a cache plugin? Did you clear cache after adding the CSS?
And can you try adding the CSS to customizer > additional CSS?
robertschmidt
yes I cleared the wpengine cache and also the wprocket cache.
Now it’s sticky. Please check!
robertschmidt
I think I got this all working now, including the search. Can you please confirm?
All yeah, everything is working now 🙂
robertschmidt
The sticky header isn’t working on mobile. Is there a way to make it work?
You are using a mobile header on mobile, I’ve updated the CSS:
https://generate.support/topic/sticky-header-3/#post-156528 -
robertschmidt
This is great, thank you.
