Sticky header height on mobile
  • I have a sticky header with primary navigation. On mobile I would like to reduce the height because there is too much white space above and below the logo, menu button etc. I can’t figure out how to do this. Can you help me with this?
    edit the Termin buchen button, and in the Mobile preview, edit the blocks Spacing and remove the Top and Bottom Margins
  • Hi David,
    thanks for your quick reply! However, the block has no margins defined. I have set top and bottom margin to -20 once and then back to 0, and now the header has the correct height. So the issue is solved.
  • Glad to hear that
