Sticky Header Transition Smoothly
  • Hello there,
    How to make this sticky header transition smoothly?
    I attached the link below
    Thank you
    Could you temporarily disable the Sticky Header option first?
    Let me know once that’s done, and I’ll take another look.
  • OK,
    I already disable it
  • Okay, now select the Site Header block and apply the following settings:
    Position: Sticky
    Inset > Top: var(--space-m)
    z-index: 1
  • That’s work
    How to make it consistent for Sticky Header: When scrolling up?
    I am not seeing the transition you are describing. Are you ware of the settings found here once you select the Header block?
    Header block
