Sticky Login Button
    i like to create a sticky login button in the top right corner.
    If the user is already logged in, it should appear with his avatar image.
    If he is not logged in, there should be a standard avatar image.
    And the anchor should lead to the members page.
    Is it possible to do this with a little bit of code in generate-press?
    Thank you,
    That is quite complicated to accomplish, as it already seems to be a feature of the membership plugin. You’ll need to find a plugin that can handle this for you.
  • Hi Alvind,
    nevertheless… thank you
  • No problem David!
