Cyrielle
The person whom I’m making a website for didn’t like the fact that the sticky navigation disappears for an instant and reappears when we first slowly scroll the page, due to the ‘Fade’ transition. So I put the transition to ‘None’. But now I noticed a weird changing of size: the logo appears bigger for just a second when we scroll – see video here: https://chk.me/qylyaN1
Do you know what’s causing this and how to have a smoother transition even without the fading transition of the whole sticky nav?
I added access to the website in the private info part.
Under Customize > Layout > Sticky Navigation, try leaving the Menu Item Size field empty so it uses the default setting.
Cyrielle
Hi Alvind,
Thanks for the quick answer! It works but I originally put a smaller size in here because the logo is too big with the default setting…
Is there another solution? -
Okay, revert the previous Menu Item Size value, and do this:
Go to Customize > Layout > Header and enable Use Navigation as Header option.
Then add this CSS to restore the original navigation padding:
.main-navigation.has-branding .inside-navigation.grid-container, .main-navigation.has-branding.grid-container .inside-navigation:not(.grid-container) { padding: 20px 40px 20px 40px; } -
Cyrielle
I tried it but I still have the same issue: loom.com/share/6003ded40a49487d97fba1afd287c221
And I don’t want that much padding on the sticky navigation.
If you do not want any transition, you can use CSS instead of the GP sticky navigation.
So disable the sticky navigation, and add this CSS:
nav#site-navigation { position: sticky; top: 0; }
