Cho Na
How can I make a sticky sidebar as per the example below:
https://i.postimg.cc/8zVnT6kN/sample-right-side-bar.jpgWith a title bottom border, a round thumbnail, categories, and customized font features.
I have already created a right sidebar with the widget, but I don’t know how to customize the features above. And it’s not sticky.
I put the website example on the Private Information below, as well as other information needed. Thank you!
Create a new Block Element – Right Sidebar, switch to Code Editor and paste this markup:
<!-- wp:generateblocks/headline {"uniqueId":"96b0cc08","element":"h4","blockVersion":3,"flexBasis":"100%","iconColor":"var(\u002d\u002daccent)"} --> <h4 class="gb-headline gb-headline-96b0cc08 gb-headline-text">Most popular</h4> <!-- /wp:generateblocks/headline --> <!-- wp:generateblocks/query-loop {"uniqueId":"1a2b8d01","query":{"post_type":"post","per_page":"6"}} --> <!-- wp:generateblocks/grid {"uniqueId":"ca33760c","columns":1,"verticalGap":10,"isDynamic":true,"blockVersion":3,"isQueryLoop":true,"useLegacyRowGap":true,"lock":{"remove":true}} --> <!-- wp:generateblocks/container {"uniqueId":"5c7c4cab","isGrid":true,"isQueryLoopItem":true,"gridId":"ca33760c","isDynamic":true,"blockVersion":4,"display":"flex","flexDirectionTablet":"column","flexDirectionMobile":"row","columnGap":"20px","rowGapTablet":"10px","sizing":{"width":"100%","height":"100%","maxWidth":""},"lock":{"remove":true,"move":true}} --> <!-- wp:generateblocks/container {"uniqueId":"3df7c017","isDynamic":true,"blockVersion":4,"flexShrink":0,"flexBasis":"80px","sizing":{"width":"","widthTablet":"66.66%","widthMobile":"50%","height":"","maxWidth":""},"typography":{"textAlignTablet":"left"}} --> <!-- wp:generateblocks/image {"uniqueId":"92236877","sizeSlug":"thumbnail","width":"80px","height":"80px","objectFit":"cover","blockVersion":2,"borders":{"borderTopRightRadius":"50%","borderBottomRightRadius":"50%","borderBottomLeftRadius":"50%","borderTopLeftRadius":"50%"},"useDynamicData":true,"dynamicContentType":"featured-image"} /--> <!-- /wp:generateblocks/container --> <!-- wp:generateblocks/container {"uniqueId":"3d6aadc7","verticalAlignment":"center","isDynamic":true,"blockVersion":4,"display":"flex","flexDirection":"column","justifyContent":"center","flexShrink":1,"sizing":{"width":"","widthTablet":"100%","widthMobile":"50%","height":"100%","maxWidth":""}} --> <!-- wp:generateblocks/headline {"uniqueId":"5de65b61","element":"h6","blockVersion":3,"typography":{"fontSize":"12px"},"spacing":{"marginBottom":"8px"},"useDynamicData":true,"dynamicContentType":"terms","termTaxonomy":"category"} --> <h6 class="gb-headline gb-headline-5de65b61 gb-headline-text"></h6> <!-- /wp:generateblocks/headline --> <!-- wp:generateblocks/headline {"uniqueId":"1cf7ebe2","element":"h3","blockVersion":3,"typography":{"fontSize":"15px"},"spacing":{"marginBottom":"5px"},"useDynamicData":true,"dynamicContentType":"post-title","dynamicLinkType":"single-post"} --> <h3 class="gb-headline gb-headline-1cf7ebe2 gb-headline-text"></h3> <!-- /wp:generateblocks/headline --> <!-- /wp:generateblocks/container --> <!-- /wp:generateblocks/container --> <!-- /wp:generateblocks/grid --> <!-- /wp:generateblocks/query-loop -->
That should give you the layout like the example you provided.
Once that’s done, we can add the sticky feature afterward.
Cho Na
Hi Alvind,
I created a new element called Right Sidebar with the markup you provided and customized it as I wanted. Now, how to add the sticky feature?
Give this CSS a shot:
@media (min-width: 769px) { .single .inside-right-sidebar { position: sticky; top: 70px; } }
Learn how to add CSS: https://docs.generatepress.com/article/adding-css/
Let me know if this helps 🙂
Cho Na
Hi Leo,
I tried adding that CSS using the Simple CSS plugin as well as Additional CSS as per the link you suggested. Both don’t work.
I just checked your sidebar, and it looks like the sticky effect is already applied.
Cho Na
It seems like the sticky effect is only applied to single posts. Both archive and static pages are not sticky. It’s clearly shown on long static pages like https://chonawrites.com/privacy-policy/ or https://chonawrites.com/terms-and-conditions/, the sidebar is not sticky.
I initially thought you wanted the sticky sidebar to apply only on single posts. If that’s the case, modify Leo’s CSS above to this:
@media (min-width: 769px) { .inside-right-sidebar { position: sticky; top: 70px; } }
Cho Na
It works now! Thank you Alvind and Leo!
You’re welcome!
