Strange Spacing Errors
  • On my homepage, there’s strange spacing between a headline and an image in a post query template, and an image and headline in the footer. What can I do to fix this?
    Thanks so much for your help! Cheers Jodie
  • Hi Jodie,
    The only spacing I’m seeing is the bottom padding applied to the GB Image Block.
    Can you try reducing that? Or, are you referring to something else? If so, can you share a screenshot?
  • Hi Fernando,
    There’s no padding for the the image in the fat right hand side of the footer, yet there’s still this large gap between the bottom of it and the headline block underneath. What can I do to fix that?
  • Try adding this through Appearance > Customize > Additional CSS:
    .footer-widget-4 aside.widget{
        margin-bottom: 0;
  • Hi Fernando, thanks so much for that! All fixed.
  • You’re welcome, Jodie!
