Jack Huang
Hi, team,
In my site, the pagination url should be something like /page/2/, but now it’s https://eggtrayequipment.com/news/?query-9b95972e-page=2
Can you help take a look?
Thank you!
Jack
Hi Jack,
This is expected behavior based on how the Query block works in this setup.
Since
/news/is a regular page (not an archive), the Query block runs its own custom query to fetch posts from your News category. Because of that, it can’t use the standard/page/2/pagination format. That format is reserved for WordPress’s main query, and on a static page, the main query only represents the page itself.The
?query-xxxx-page=2parameter is how the plugin handles pagination for custom queries. It also allows multiple Query blocks on the same page to paginate independently without conflicts.So in this case, everything is working as intended and isn’t a bug.
If having clean
/page/2/URLs is important, the alternative would be to use a proper archive page for your News category (for example/category/news/) and set the Query block to inherit the query from the URL. That way, WordPress’s main query handles pagination natively. -
Jack Huang
Hi, Alvind,
Thanks for your prompt reply. The answers are always professional and precise!
You’re welcome, Jack. Glad to hear that!
