Stuck at importing step when importing new theme and layout from library
    if we look at the api-fetch script you see this is in your logs:
    api-fetch.min.js?ver=0fa4dabf8bf2c7adf21a:2
    This ?ver=0fa4dabf8bf2c7adf21a:2 is a query string used by a cache.
    Which means that file has been cached, and that cached file could have an issue.
    Can you disable any caches on the site ( plugins and server ). Then try the import
  • So blue host uses cloudflare. I removed cloudflare and imported and it worked. I wonder why it was only affecting Inbound since other templates worked fine.
    I think we can close this ticket now. Thank you.
  • Glad to hear you got it working.
Viewing 3 posts - 17 through 19 (of 19 total)
